GregValiant 1,318
That isn't the StartUp Gcode from the Anet A8 definition file. There are some typos in it as well.
The Creality Ender 5 is a "backwards" machine that has the 0,0,0 origin at the back right. It doesn't affect anything but the users view while a model is printing.
Before going into things that no one ever has to adjust, load a Benchy or calibration cube and set Cura up to slice. Use the File | Save Project command to create a 3mf project file, then zip the file and post the zip folder here.
When you "Auto-Home" the printer from the LCD where does the nozzle end up?
When you load a model in Cura and its at the midpoint of the build plate - where does it print on the real build plate of the printer?
Edited by GregValiant
surleversant 0
Got the decision. Insert the code:
M104 S200
M105
M109 S200
M82 ;absolute extrusion mode
G28:Home
G1 Z15.0 F6000;Move the platfarm down 15mm;
prime the extruder
G92 E0
G1 F200 E3
G92 E0
G92 E0
G1 F1500 E-10
;LAYER_COUNT:1001
in the beginning, instead of generated by Cura.
