Posted (edited) · Ultimaker S5 fail at the end of every print
I have this problem with newer version of Cura (5.3 & 5.4). At the end of the print, the Ultimaker S5 lets the print core 2 cool down before retracting the material. This cause the retraction to fail every time I'm not using PLA. Is there a way to fix this problem?
Thanks in advance
Edited by par
    Hi mrender,
    The final printing temperature I use for ABS is 235 °C. After the printing, the print core will go as low as 75 °C before retracting.
    It really seems like a sequence error of some sort (Retraction should be before cooldown). Note that the print core 1 is doing the sequence ok.
    Edited by par
