Lift Model Off Build Plate
Go to solution Solved by obewan,
Posted · Lift Model Off Build Plate
I'm using Cura 5.3.0 on Linux, with an Entina Tina2 printer.
I want to improve the clean-up of the undersides of prints by raising the model off the z=0 plane, and thus have support structure under the entire model.  I've turned off snapping to zero and set z=10mm (say), but although the Prepare view shows the model off the bed, when I slice and view Preview the model is back on the base (with a "ghost" of the model shown where it should be).  Scanning through the layers in Preview shows the build at z=0.
Some Google results say that's what to do, but others indicate the z offset is to make the printer start on top of an object placed on the print bed.
What to do please?  I don't want to just "suck it and see" without some advice.  Thanks.
    It's interesting you mention that, because I found it too.  However, although it's ticked to be displayed in the menus in Preferences,  I can't actually find it in Print Settings!  Why would that be?
    Aha!  https://github.com/Ultimaker/Cura/issues/15505
    Quote
    This is a known bug in the last couple of versions of Cura. There is a workaround.
    • Disable "Generate Supports"
    • In the Mesh Fixes section disable "Remove Empty First Layers"
    • Re-enable "Generate Supports"
    The setting is improperly hidden when Generate Supports is active.
    Posted (edited) · Lift Model Off Build Plate
    The above gave me exactly the preview I wanted.
    Unfortunately the resulting GCode upset my printer (Tina2) to the extent that it tried to print the adhesion raft below the level of the bed!
    UPDATE: False alarm!
    I spent ages looking at the GCode and comparing it with a previous run (without the model's Z offset), and couldn't find any significant differences.  So I prepared to re-run the same print file.
    By a strange coincidence, the Tina2's z offset calibration had gone awry.  I recalibrated it, and the print is now proceeding correctly (apparently).
    Edited by CrazyIvan2
