Sorry, I may have misspoke. I didn't mean floating in the air, I meant force supports etc so by 3mm above the bed everything should be level and flat and start printing the actual model there. I guess I can model my own supports externally?
We have the bed close to level by shimming under the flexible sheet, but I don't think we will get it glass smooth flat and level.
If the two halved didn't have to exactly mate, it wouldn't matter. We use it for other prints all the time and are very happy with it. We assumed it to be level until we did this print and were surprised to see they would not mate.
GregValiant 1,492
The Z=0 is set by leveling. If the bed isn't flat, and all your mechanicals are always at 90° to each other and stay "in plane" while printing, then you really need to fix the bed because you have a hardware problem. You cannot print in the air.
Some of the upscale ABL systems will compensate for an uneven bed over the first couple of layers so that by (call it) layer 3 the print is leveled out. There will be areas of over and under extrusion because of that. The reason is that the E values in the gcode were calculated for a level surface and not one where the Z keeps changing randomly.
You need to address the bed problem. If the waviness is random it's tough but if you know the low spots then stick a custom cut-out piece of aluminum foil (or 3) under the magnetic surface to shim certain areas up.
An alternative would be to go with a glass surface even if it's just for this one job.
