Slash, of course the one time I don't make a .3mf project file this happens. So, here is an after the fact version. I did make an html "project file" for my records so I've been able to verify the slicer settings. No proof I've made this .3mf file 100% accurately but it is darned close.
Only thing I don't see here is that the printer was in a chamber heated to 105F or 40c. I can make it hotter but this appears to work.
Advice is what makes the world turn so never hesitate to give any and all to me.
BTW, is it possible that this behavior is from under-extrusion by the filament getting temporarily stuck on the spool? I'm going to a dual gear extruder, just because I have one, but perhaps all my el-cheapo equipment somehow caused this?
Please understand, I don't know under-extrude from over-extrude so the use of those words is just me grasping. Yes I know what the words mean but visually? I know very little.
Sad, I know. :-)
TYVM, PDC
Slashee_the_Cow 421
If you could provide the .3mf file (File > Save Project in Cura) that always helps us sleuths.
I will offer one piece of advice which I'm told I offer too readily: if you used Cura 5.4, that has some known bugs when it comes to slicing, try slicing it Cura 5.3.1 (don't have to uninstall 5.4, you can run them side by side) and see if that makes a difference. Although this doesn't look like the sort of problems which usually come up with 5.4, so take that with a grain of salt if you want.
