Problems with printed pieces in Ultimaker S5
AnaLara
Posted · Problems with printed pieces in Ultimaker S5
Hi all,
I would like to ask you what is the problem if my pieces are printed in this way, with so many deffects in the surface.
I do not know if the problems is about the printer of the parameters of Ultimaker Cura, I am using Ultimaker S5.
Thank you so much.
Best regards.
