Slicing direction?
Go to solution Solved by Slashee_the_Cow,
Posted · Slicing direction?
Slicer works this way:
First it prints "1" north-east to south-west
Then it doesn't move the print head north for "2", it simply slices it the other way around (south-west to north-east)
Then it hast to jump over the printed stuff, and prints the "3" north-east to south-west
I  would like it to print in the same order (1, 2, 3), but I would like it to print it always north-east to south-west.
Is there a setting I can change to make it so?
Photo attached - all I want it to do is print "2" in the same direction as "1" and "3"
    Posted (edited) · Slicing direction?
    I'm printing a thin thing and it needs to be as smooth as possible while being completely filled up (no holes)
    I'm using 102% extrusion for that purpose so there's a bit of extra material being "pushed".
    When the second step goes in the "wrong direction", fresh pushed material meets old pushed material from the first step, and I get too much material at that point
    Then the third step starts printing and it's perfect at continuation of first step, and looks a bit different at the continuation of the second step...
    Also, when you look at the final print, you can see a different pattern at step 2 because it's printed in the other direction.
    I made a quick STL if you want to play with it. It behaves exactly the same.
    Test-slicer.stl
    Edited by Zlutz
    added the file
    • Solution
    Go to Top / Bottom and turn on Monotonic Top/Bottom Order
    Well thank you very much, my bovine friend! This is EXACTLY what I was looking for.
    I would never think to search for "monotonic" or think it has anything to do with "top/bottom" options... 😄
    The funny thing is, this part would take 1:18 to print with and without this option so it doesn't cost anything!
    Always happy to lift someone's MOOd (sorry, I have to milk all I can out of the cow puns). I can understand why 99% of people would look at the title and go straight past it, but I have too much free time so I can try these things to see what happens 🙂
