Hello.
On the flip side of things,
In 5.4 when I import multiple parts exported from F360 in 3mf format, The models will be position correctly as per in F360.
But in later versions, importing the models in 3mf just centers them all. I need to print a multi part model as one.
I cant find, but is it a function that can be turned back on?
Slashee_the_Cow 271
Fusion 3D exports files with objects' transform origins in different co-ordinates to what Cura uses, which is why things appear in the wrong location upon loading the file.
There is an easy way to drop all models to the build plate though: once you've opened the 3mf file, press Ctrl+A to select all the objects, then click the move button in the sidebar and set Z to 0 (and then turn on drop down model if it isn't already on might be a good idea) and it will affect all of them.
Edited by Slashee_the_CowLink to post
