Of coure.
Interestingly, it does well at 0.1 mm layer height. But as I know, this is not supported by Ender 3.
Edited by kerekesOf coure.
Edited by kerekesIt's drawing a first layer of skin to cover the gap that ends in the previous layer - it's considered a new area so it's drawing the first skin wall (because you have Extra Skin Wall Count set to 1, which is a good idea, anyway...
Edit: Accidentally hit post button. Will continue below.
Edited by Slashee_the_CowBecause your line width is roughly the size of the gap, it thinks it'll get enough adhesion from the overhang of the layers below it to put it there - you can test this by lowering your line width to 0.33mm (or lower).
But first, I'd like to point a serious "WTF" in your print settings: You have bottom layers set to 999999. This will make the whole object skin with no infill. 100% infill will be as strong but print a bit quicker and use a little less material doing it. That, and the slicer really isn't designed for doing it that way, so it might actually be a bit weaker to do it with skin.
Setting it so you have a reasonable number of top and bottom layers (usually based on thickness so it adapts to different layer heights, I usually go for 0.6-0.8mm depending on how strong I want something to be (or how frugal I'm being with my filament) so that the inside of it actually uses infill is standard practice. That being said, it won't actually change this behaviour by itself, but it does give you more options to.
Probably partial list of things that will affect its behaviour:
Conclusion: For the love all things beefy, use a reasonable thickness of skin layers but then use infill. You can probably get away without fixing it, since you're not going to be able to see it through a tiny gap and it's covered by at least a couple more layers of skin above it which should hide it.
Slashee_the_Cow 271
Can you please provide the .3mf file (in Cura, go to File > Save Project) so we can have a look at it? A few screenshots aren't really that much to go on most of the time.
