9 minutes ago, Slashee_the_Cow said:If you could provide the .3mf file (go to File > Save Project in Cura) that would help. It looks like a problem with ...
Sorry I won't have access to the file until tomorrow.
I'm not sure it's the Z seam, these lines go around the part. And interestingly the cylinder part doesn't have this problem.
I sliced the cylinder (as in the image above), with the same settings and it turned out perfect.
Nothing changed regarding firmware. Same filmanet.
Printer: Guider II by Flashforge
Slashee_the_Cow 382
If you could provide the .3mf file (go to File > Save Project in Cura) that would help. It looks like a problem with extrusion, possibly around the Z seam.
Some more information would help - have you sliced other things successfully before using the same software and the same settings? Has anything changed on your printer's end - firmware update? Different filament? What printer is it?
