I actually have a ultimaker reprap called joysmaker r2, this url will show some pics of it, mine is the wooden one:
http://item.taobao.com/item.htm?id=16857610502
I also added here some pics of my printer head so you could see.
It´s pretty similar to ultimaker original as they went open source, they made some changes in the next release the r2, the same as mine, they added a heated bed, the design a little and some other small modifications that I don´t know.
What you said actually makes sense, as it moves the wire would short circuit or something. But mine doesn´t seem to have an extra set of wires.
I was thinking the wires of the thermometer are to blame? what do you think, maybe the heater wires instead?
And where exactly right on the base of the thermometer/heater or along the way?
and if right on the base, is there a way for me to chage it there? it looks like there´s now way to get inside the heater or the thermometer, and the wires look as though they are going straight inside without any connection to fix it.
gr5 1,968
Do you have an Ultimaker Original? This is very common on the UM1. It often starts happening after the printer is many months old. Usually the problem is in the wire on the print head. You can heat the nozzle to say 100C and then push the head around to the 4 corners while watching the temperature and duplicate the problem. Also you can duplicate it by pushing on the wires on the top of the print head. The easier fix is to use the extra cable already installed - the cable hanging loose that isn't used - that is meant for a second nozzle. Unplug the current cable and plug that in at the head. Do the same thing underneath the ultimaker at the PCB.
But this time make sure the wiring goes through the black strain relief shaped like a F so it won't break again.
