Cura 5.X is not loading any .stl model (log provided)
It is definitely trying to connect to all your devices to see if it can get a successful connection to a printer. My brute force advice would be to go to the Cura plugins folder (for the program, not the config folder) which appears to be at /Applications/UltiMaker Cura.app/Contents/MacOS/share/cura/plugins/ (sorry, don't have a Mac) and move the folders for the following plugins somewhere else (just up one folder should be fine):
USBPrinting
Actually trying just that one first might work, especially with the baud rate it's definitely trying to connect to all these devices as printers. The sledgehammer approach would also mean moving these out of the plugins folder:
FimwareUpdateChecker
FirmwareUpdater
UM3NetworkPrinting
Although it is possible trying to connect to all these devices is unrelated to models not loading. But hey, eliminate the possibilities one by one.
Slashee_the_Cow 269
These lines (3444-3462) I find interesting but it's possible they're just errors in the UI and wouldn't cause your problem:
The last lines in the log don't seem to indicate any errors:
USBPrinting
FirmwareUpdater
UM3NetworkPrinting
