@JoshofAllTrades Cura adds some g-code before the "Starting G-code"
;Generated with Cura_SteamEngine 5.5.0
T0
M190 S100
M104 S230
M104 S230
M116
M82 ;absolute extrusion mode
The command M190 does heat the bed to the material temp in the cura setting, but that command does not hold the temperature.
Does anyone know how to change the code generated by Cura?
Slashee_the_Cow 271
Not sure exactly what the problem with origin is but the main one is if a printer considers the centre of the bed as the origin instead of the front left corner. There's a toggle for Origin at center in the printer settings. If it's taking the origin as slightly away from where it should be, then just set the nozzle offsets for your extruders to the opposite of that to compensate.
