If I remember correctly, I read that if your computer goes into standby it breaks the link to your printer.. turn off your PC's energy saving settings so your PC stays on should cure the issue.
2 hours ago, dbrandwood said:If I remember correctly, I read that if your computer goes into standby it breaks the link to your printer.. turn off your PC's energy saving settings so your PC stays on should cure the issue.
You remember correctly. However, printing directly from your PC is still not a great idea, as there's plenty of ways it can go wrong (like something freezes hard and you have to reboot).
1
Slashee_the_Cow 382
Were you printing through Cura (which really only exists for legacy reasons) or using an SD card or a system like OctoPrint? If it's not the first, it's not really Cura's fault, and if it is the first, you should probably try the second, if available.
Still if you could please post the .3mf file for your project (in Cura go to File > Save Project) and the generated gcode we can have a look and see if there's anything that stands out as wrong.
Bennjell 0
Thank you you for your help! I printed all the time via USB-PC connection. Today I switsched to OctoPrint. Now the print didnt abort:) So the connection between pc and printer was the problem. I sliced it with cura the same as the past prints.
