Posted (edited) · How can I print these fine details?
Those walls are getting negative horizontal expansioned out of existence, and they're too thin for the default anyway.
Set Walls > Horizontal Expansion to 0
And set Walls > Minimum Wall Line Width lower - in my testing based on your project file, it needs to be 0.13mm or lower (although Cura will warn you if you set it to 0.12mm or lower, meaning "your printer might not be able to handle this"), so if you try 0.13mm and can't see them, try changing it down in tiny steps (like 0.129mm, 0.128mm, and so on) until you can.
Edited by Slashee_the_Cow
fixed typo
