I have not, just found the thread, thank you. The issue in that thread was not resolved but Daid said on 12/19/13 that new U1 firmware would be coming with the next Cura update, which should fix the PID bugs. Has there been a firmware update since then?
illuminarti 18
Have you re calibrated the PID settings since installing the new hotend? I seem to recall that someone else had similar issues related to the different power to thermal mass ratio of alternative hot ends, but I'm not sure how they fixed it.
