Octoprint Issue
Andyv64m
Posted · Octoprint Issue
I have multiple 3D printers and 2 of them have a raspberry PI running Octoprint but I'm having real issues when I want to run a print from Cura. The reason being if I have both printers turned on running Octoprint if I select the creality printer and try to print I get an API error. When I go and look at the IP address for the creality printer its got the Ultimaker IP address in there, If I refresh several times it will then retrieve the correct IP address for the Creality printer and even sometimes let me print with it. I dont get this problem if I dont have both printers turned on at the same time and Cura always get the right printer and IP address.
How do I fix this????
