3 hours ago, Rudolfje said:I should probably post the error on the Cura GitHub repo, but I was more interested in fixing my immediate problem.
The developers are so sick of looking for this bug that in 5.7.0 they added automatic slicing error reporting. Just make sure you have the Send engine crash reports setting in the Privacy section of the Cura preferences turned on:
It's almost certainly not a problem with any particular quality profile setting. Sometimes you can get a successful slice after changing a setting (almost any of them, really) to something different, slicing, then changing it back and slicing it again. Or move your model slightly on the build plate and slice again.
Slashee_the_Cow 274
Please post slicing failed errors here on the Cura GitHib repo so the developers can look into it.
Rudolfje 0
For anyone hitting this post with the same error:
I also got this error, but I fixed it by selecting one of the default slicing profiles like "Dynamic Quality - 0.16 mm".
So I probably created the error by selecting something odd in the Advanced profile settings.
Starting with a fresh profile and adjusting settings and checking regularly if it's still working seems like a good idea...
Sorry, about that 🫤
