Ender 3 V3 SE doesn't extrude when using Cura, but does when using Creality Slicer
Posted
· Ender 3 V3 SE doesn't extrude when using Cura, but does when using Creality Slicer
I'm not sure about the configuration (probably requires someone more daring or smarter than me to get the configuration file from the motherboard) for the E3V3SE but the default in Marlin is that it won't extrude below 170° if PREVENT_COLD_EXTRUSION is enabled.
You can override it for a print in gcode if you want, but... you probably shouldn't. Lowest I've ever printed was 180° and that was for some dodgy PLA.
1
Slashee_the_Cow 270
