Posted · I cannot find my printer in Cura
Hey,
I have the maker select plus 3d printer, and I cannot find it under the list of available 3d printers. What should i do? Should I do a custom and manualy input information, or is there a similar printer i can you as a base?
Much apprecited.
    Try searching the web, a lot of the time if there isn't a built in profile (which are submitted by the community to the Cura source repository, but that's a slightly long and painful process) someone will have posted either an entire profile or instructions.
    If you can't find anything somewhere else, only use a printer that you know is similar to yours as a base. I don't just mean build volume, there's also things like gcode flavour and its origin that can be different. If you don't know any printers that are similar to yours (and already have a profile) to base it on, then you'll probably have to go custom.
