For the Ultimaker S5, the Type AA print core is generally used for printing build materials like PLA, PETG, and ABS, as well as Breakaway support material. The Type BB print core is optimized for water-soluble PVA support material. Since you’re printing a box, which is a build material, the AA print core would be more suitable. If you need to print with materials that are too thick for the AA 0.4mm, consider using a print core with a larger nozzle size, such as the AA 0.8mm, if available for your material.
Dustin 193
Who's RS team?
