3D printer causes drops in the middle of infill pattern bottom layer
Dustin 132
Looks like your either printing too fast or extruder is set too cold..
You also appear to be slightly too close to the bed surface when printing..
The excessive amounts of material being shown is when the hotend is finely able to release built up back pressure.
