What format is the file you're trying to print? 3MF files can contain object co-ordinates so if you're loading something you set up with a smaller bed it might be positioning them where they would be on the smaller bed. STL files should load in the centre of the bed.
If you could provide a screenshot of where it is loading the models (if the above isn't the case) it might help.
Hello I updated cura from 4.8 to 5.5 and added my printer size and it works perfectly now I'm just having a problem trying to level the bed and getting the first layer to stick
Slashee_the_Cow 276
