yes, i have! 2.00 to the v3 se and 6.5 to the regular ender 3. i figured that if i print in 0.28 layer height helps to eliminate the nods! thanks
On my E3V3SE, I set the retraction distance to 0.8mm if I'm using PLA. For PETG or TPU I use 2mm because they're a lot stringier. If you have a decent quality filament it shouldn't make too much of a difference, but especially with a direct drive extruder, the less you retract, the better, because going back and forward going through the gears grinds it up a bit.
Also, the E3V3SE retracts faster than the others thanks to its direct drive extruder, I set it to 40mm/s (which is I think what Creality recommends).
Edited by Slashee_the_Cow
Slashee_the_Cow 276
Have you made sure to set the retraction settings correctly for each printer (separately, because the E3V3SE uses a direct drive extruder which requires significantly less retraction)? It looks like it's just not retracting properly where it should be.
