Posted
(edited)
· Option to remove automatic added filaments
If you install the Startup Optimiser plugin (available from the Marketplace inside Cura, though you may need to log out in Cura before you can install that plugin), you can use the option to "Load only 'generic' and custom materials" option. Then restart, and all the branded materials will be gone.
Edit: with @Alain_D's screenshot, and my description, you should be able to figure it out 😉
Alain_D 3
There is a plugin : Starup Optimiser
ahoeben 1,951
Edited by ahoebenLink to post
Estate 0
Thanks, didn't know that option was there 🙂
