Thank you for the reply,
Yes, the bed has been properly leveled (see picture). I have been using the auto z offset, I have not used the manual z offset when I auto level the bed, I will try this. I have auto leveled the bed after every successful print which is about 10 times.
Yes, it is a 0.8mm nozzle, thank you for the correction. I can switch to a .6 or to a .4 if that is what it takes. I did try running the layer height at .6 but the layers did not adhere to each other very well.
I am using PLA+. To clarify, the nozzle and bed temps I stated were the maximum temperatures for the PLA I am using, my printer can go much higher.
I am actually using raft + zigzag supports (this way the entire print sits atop the raft), but I had to try without bed adhesion and support to see if it did the same thing, which it did. I can try different orientations of the print as well; I am open to anything.
I'm on my way to run some errands but once I return, I will run the bed calibration and manually offset the Z, reconfigure that file, run it with the .4 nozzle and attempt to print it again. I will repost my findings once it is succeeds or fails. (I hope it succeeds).
Again, thank you for the input.
Slashee_the_Cow 276
If you could provide the Cura project file (.3mf, get it ready to print then go to File > Save Project in Cura that would help a lot, as well as the gcode you're trying to print... and not to ask too much but a photo or something to show what's going wrong would really help.
But firstly:
