UltiMaker Cura 5.5 and 5.6 Changing Printer Machine Settings
Could you please post a screenshot and a log file (in Cura, go to Help > Show configuration folder and the filename is cura.log) so we can see more?
I have experienced what (I think, based on your description) is a similar problem, caused by the "Settings Guide" plugin, if you have it. The help screen covers the whole window when you're trying to trying to change the start/end gcode settings. You can fix this by making the machine settings dialog larger by dragging the corners of the window outward.
Slashee_the_Cow 267
