The fix-horrible type change slightly the place of the lines, but does'nt solve the problem. Here is an image:
from my experience. it is better to export your model without the glass in the windows and doors. it is just extra data that cannot be printed at the scale of an ultimaker print. it is better if you remove all the small tiny elements within a window and just have the outside frame. if you need the inside frame, increase the dimensions so they are printable...
mini mini details and super thin parts are no help to you or the print process... I learned that the hard way !
Ian :-)
I agree with you, but to have cura automaticaly ignore them was a great help for not wasting time: I could use the same model for the plans printing and for the 3dprinting.
But if I want to see the doors and windows printed, then I have no choice than to make them thicker.
Daid 301
Could be that the fix-horrible type A (which was default off in 13.12, default on as of 14.01) be causing this.
