Question: 2-Tier Cura deployment, Fronted (Gui) + Backend (Backend "uranium" component) = Distributed + Faster Processing
Posted · Question: 2-Tier Cura deployment, Fronted (Gui) + Backend (Backend "uranium" component) = Distributed + Faster Processing
There is some implementation of a 2-tier for CURA?
We have two computers, 1 a standard laptop where we run the CURA Gui where we do the stuff related to the positioning on the building area and so one.
And a second server that have a 32 vCPU cores, but has not possibility of interactive session. But I would put over this server the load corresponding to the slicing process. That's the "uranium" component if I'm not wrong, that is started by the gui and accessed using a loopback tcp/ip connection thru a socket created ad-hoc for the engine execution.
It's possible to segregate the Backend process to an external server that could process faster the slicing load?
Thanks.
