Posted
(edited)
· Schicht über dem infill richtig einstellen.
Infill will always extend through any connected volume up into the next volume. You can change that by increasing the "Skin Expand Distance" which you will find near the bottom of the "Top Bottom Settings".
These are the same model. I used the "Per Model" settings and the one on the right has the "Skin Expand Distance" set to 8 while the left model is at 1.2.
Edited by GregValiant
GregValiant 1,260
