I too am experiencing this same issue, but no matter what I do to change the "Custom Selection" to something else (such as Expert or All), it flat refuses to change the Print Settings panel from anything but the Basic Settings display. I've even confirmed that the Setting Visibility is indeed being saved by Cura by changing printers. What gives???
Slashee_the_Cow 272
In the print settings dropdown in the top right, click Show Custom. This should transform it into the settings panel you know and love. Then there'll be the menu button in the top right with three horizontal lines which allow you to select which settings are visible.
You might have accidentally clicked "Recommended" at the bottom of the full settings menu, which takes you back to the basic settings.
Edited by Slashee_the_Cowfixed typo
