Hi "ahoeben",
thanks for your promt reply...
For testing I must erase the M900 command from the setting I already set with Pronterface by the input "M900 K.0.65" - "send" - M503
It's now listet as "echo: M900 K0.65"
Do you (or anyone else) know if there is any instruction to delete this line with the terminal tool of Pronterface?
Or can I leave it there and Cura will override the value?
Regards
Michael
ahoeben 1,949
That's how it is supposed to work, yes.
I am the creator of the Linear Advance plugin, but I don't have a 3d printer capable of linear advance myself, so I don't know how well it actually works. If it doesn't, see https://github.com/fieldOfView/Cura-LinearAdvanceSettingPlugin/issues
