Uninstalled, removed all artifacts of, and Re-installed Cura 5.6.0 - Same Issue
Did you remove (or in my case I'd just rename so I've got a backup) the whole Cura config folder (%APPDATA\cura\)?. If you have settings/plugins/whatever from a previous version in there it'll just migrate them when you first launch 5.6 (or whatever version you try) and if somehow they're messed up that will copy over). You don't have to reinstall Cura or anything, just make sure no versions of Cura are open and rename the folder.
You shouldn't need to change the compatibility settings (and if you did, I'd change them back).
7 hours ago, dvlstx said:
Creality Slicer V4.8 - has the same issue
Have you tried Creality Print? Totally not a confusing name, but it's based on a newer version of Cura.
Speaking of that, have you tried an older version of Cura? See if 4.13.1 works. I'm not saying using it all the time is a solution, just a test to see if it behaves any differently.
Slashee_the_Cow 267
