Thanks, I did report the error in git already.
The error only occures during the calculation of the supports and there it has different causes. Since it's a new error since 5.6 I just wanted to confirm, that I am not missing something.
Thanks for your answer!
Slashee_the_Cow 267
There's a whole bunch of things that can give Cura hissy fit and slicing fails. Sometimes even changing a setting then changing it back will make it slice. Also try moving your model just a teensy bit on the build plate.
To answer your specific question: not that I know of. If you can get something to consistently fail, report it on the Cura GitHub repo.
