Afterwards, I ran the format one more time, but the results were no different.
As you commented, I entered "echo %TEMP%" in the command prompt and ran it, but the result was the same.
ESTsoft is one of the PDF viewers used in Korea. As you commented, when I run Cura after deleting it, the following error appears.
Slashee_the_Cow 272
I have no idea why why it would be trying to use "C:\Users\Public\Documents\ESTsoft\CreatorTemp\". If you have any programs from ESTsoft, I'd try uninstalling them and seeing what happens.
But before you do that, open a command prompt and run echo %TEMP% and post the result.
