Posted
· Einrichtungsprobleme mit Elegoo neptune 4 pro
Hello.
The Neptune 4 Pro definition will likely be included in Cura 5.7. For now, install a Neptune 3 Pro.
There may be some things that are slightly different but the two models have a lot in common. So long as the Machine Settings match your 4 Pro you should be able to get started.
If you do a search on Reddit a lot of your questions may already have been answered.
GregValiant 1,253
Hello.
