Bibo dual 3d Printer / Cura 5.6
Posted · Bibo dual 3d Printer / Cura 5.6
I'm at a loss, I download my files from Cults 3D, I Slice my files in UltiMaker Cura 5.6.0
Print on BIBO printer.
Everything was fine and working properly, but now after I cut and try and print files, it heats the bed.
But the temp set for each extruder stays at zero.
The other files on my sd card still print and show the print temp where 0 is on. I seemed to have changed or modified some setting that is changing the slice to never heat and start the print.
Drink champ file 0/0 0/0 0/60 ( but the bed will heat to 60/60  and stay)
F150 file 22/200 ( heating) 23/0 37/60 ( bed heating) - good file printed x2
I do not think its a G code issue / possibly a filament setting...
F150 file prints fine, its all files sliced post that file, but cant seem to find a setting isssue.
B2D_SAURO.gcode B2D_drinkChamp.3mf
    Tried to uninstall UltiMaker, but after I re install, it seems to just have saved all my settings. Cant figure out how to reset to a new printer, wont let me delete in Cura.
    Running G-Code : Marlin , not sure if that matters
    There is a guide for completely resetting UltiMaker Cura to fresh install status
    Note: this deletes any settings or profiles you might have made
    here: https://support.ultimaker.com/s/article/1667337567843
    Posted (edited) · Bibo dual 3d Printer / Cura 5.6
    This is the first line in that Gcode file:
    ;FLAVOR:UltiGCode
    Which I believe is UltiMaker specific.
    This is from your printer definition file:
    "machine_gcode_flavor": { "default_value": "RepRap (Marlin/Sprinter)" }
    that indicates you have the wrong Gcode flavor in the Machine Settings.  Unless you are absolutely positive that your machine is running Ultigcode you should change the setting to "Marlin".
    There is a Cura bug that affects some dual extruder printers if the Tool Numbers are called out in the StartUp gcode.  You can try simplifying your startup and just allow Cura to handle the heating of the extruders and the bed.  I believe the bug has been addressed and should be fixed in 5.7.
    If you use this as the StartUp Gcode it will eliminate the {initial_extruder_nr} which has the bug (it's always "0" regardless of which extruder starts a print):
    ;---StartUp Gcode
    G21 ;metric values
    G90 ;absolute positioning
    M220 S100 ;reset the feed rate to 100%
    M221 S100 ; reset the flow rate to 100%
    M107 ;start with the fan off
    G28 ; Auto-Home all axes
    G1 Z2.0 F400 ;move the platform down 2mm
    M117 BIBO printing...
    ;---End of StartUp
    If you use that then the start of a gcode file will look like this (using Marlin as the gcode flavor):
    T0
    M140 S60
    M105
    M190 S60
    M104 S200
    M104 T1 S175
    M105
    M109 S200
    M105
    M109 T1 S175
    M82 ;absolute extrusion mode
    ;---StartUp Gcode
    G21 ;metric values
    G92 E0
    ;---End of StartUp
    G92 E0
    G1 F1500 E-6.5
    ;LAYER_COUNT:158
    ;LAYER:0
    Edited by GregValiant
    Thank you, Greg!  I was seeing this issue on Cura 5.6 and your start code fixed it.
