Cura starts up and I can load a STL file. But after the slicing command an error is displayed:
Slicing failed with an unexpected error. Please consider reporting a bug on our issue tracker.
I include the file cura.log
Thanks for your response!
It looks like the problem is the CuraEngineTiledInfill plugin which was introduced in 5.6. If you're using it, switch to one of the normal infill patterns. If you're not using it, try disabling it:
Yep! I uninstalled this extension and now Cura is slicing the model.
But at startup from the terminal there are still some errorr messages:
harry@harry-HP-ZBook-15-G3:~/Downloads/Software/Cura$ ./UltiMaker-Cura-5.6.0-linux-X64.AppImage
PyInstaller/loader/pyimod02_importers.py:352: DeprecationWarning: the imp module is deprecated in favour of importlib and slated for removal in Python 3.12; see the module's documentation for alternative uses
Gtk-Message: 13:56:01.115: Failed to load module "xapp-gtk3-module"
Cyclic dependency detected between "file:///tmp/.mount_UltiMaSp0w5U/share/cura/resources/qml/Actions.qml" and "file:///tmp/.mount_UltiMaSp0w5U/share/cura/resources/qml/Actions.qml"
Would be best to report this issue on Github
here: https://github.com/Ultimaker/Cura/issues
10 hours ago, Carnel said:Yep! I uninstalled this extension and now Cura is slicing the model.
Yeah, that happens. But as long as Cura is working, don't worry about it.
Slashee_the_Cow 271
*firesup Mint VM*
I get that cyclic dependency error warning too (Qt is a bitch) but the program itself runs fine.
If the program isn't loading, could you please upload your ~/.local/share/cura/5.6/cura.log file?
