They don't really have a fixed life span, as you noted it depends on many factors.
Often issues with under extrusion can be addressed by cleaning the core
Guide here: https://support.ultimaker.com/s/article/1667337928445
Dustin 130
Outside of that often under extrusion can be due to bad settings in UltiMaker Cura or even simply a dirty front fan on the print head
https://support.ultimaker.com/s/article/1667410987947
