Thanks for the tip on the skin setting. I did hit the function icon and it gave me a line width of 0.42, so I'm assuming I need to adjust that down.
Oddly enough though, in the previous version of Cura, my original settings worked perfectly and I didn't have this weird rippling.
Since I need to get this print done, I just set top surface skin layers to 0 and it's printing fine that way. I'll try the next print with these updated settings.
Slashee_the_Cow 271
I'm going to assume you're using a 0.4mm nozzle (it's what comes in the E3V3SE). 0.2mm line width isn't something you can reliably pully off using a 0.4mm nozzle - that's why the box is shaded yellow (the general guideline says to start at about 60% of the nozzle's width, which is 0.26mm for a 0.4mm nozzle). Trying to draw lines too think will result in too low pressure in the nozzle so it'll tend to come out in spurts every time the pressure gets high enough. Don't worry though, you can get a nice smooth finish AND not reduce your line width in the process!
That's it! You can leave the other ironing settings at default. I've used this to produce multicolour (changing filament at certain layers) art prints, and they are smooth.
