Attached is the 'cura.log' file. The file was over 5mb so I copied and cleared the file then tried to load the 3mf file.
Did you close Cura before you uploaded the log file? It ends immediately after trying (and failing) to load the model:
2024-02-11 08:38:23,351 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1829]: Attempting to read file file:///D:/Downloads/AxiomPla.3mf 2024-02-11 08:38:23,366 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=0), took 0ms
No I did not close Cura, I have attached the latest log file after closing Cura.
- Solution
Thanks for all the help, I did find the problem in %APPDATA% folder.
It does now read and write 3mf files.
Slashee_the_Cow 274
Loads fine in 5.6 for me.
On your other computer, try loading the file, then quit Cura and upload your Cura log file - it's at %APPDATA%\cura\5.6\cura.log and we can have a look and see if anything shows up.
