Can't find Neptune 4 Max 3D printer to add in Cura
GregValiant 1,255
It should be added in Cura 5.7 when it is released.
The 4 Max definition file is HERE. It might also require any supporting files (extruders, nozzles, quality, etc.).
You might be able to add a Neptune 3 and then make any changes that you see in that 4 Max file (bed size, startup gcode, etc.). That might work.
Maybe.
Possibly.
