4 hours ago, displaynamenotallowed said:Dustin do you know what I need to do to get my part cooling fan to run only on bridging/top layers?
You keep saying "part cooling fan" - does your printer have more than one addressable fan (in which case you check the gcode to make sure there are M106 lines using the correct fan index) or just as opposed to the one that cools the hot end and is controlled by the printer's motherboard?
Also... why do you want the fan on only for the bridges? PLA is usually printed with the fan on (in my experience) and by the sounds of it it's even more important for your lightweight PLA, even when not bridging (the quicker it sets, the less chance it will be affected by the future moves of the print head, or sag if you're doing an overhang).
It might be possible to brute force it using a post-processing script, but I've only used Cura versions older than 3.6 and significantly newer than 3.6, so I don't know if it even supports those (and if it does, how different they are to newer ones).
It's also worth trying in the latest version, at the very least to see if it works. If it works in 5.6 then I don't know if we can offer much more help because 3.6 is so old and hasn't been officially supported for years.
Dustin 193
Cura 3.6.. is almost 6yrs old.... its very outdated..
displaynamenotallowed 2
The developers put more time and effort into a number of aspects of 3.6
The GUI for example is better than in version 4 that I've seen.
I like 3.6 for what I'm doing aside from the slow refresh rate of the GUI.
