Oh my goodness that is so so so helpful!!! Thank you so much!!!!
The holes i made are instantly getting filled in the moment I lay the stl flat on the build plate
Go to solution
Solved by Slashee_the_Cow,
Slashee_the_Cow 269
Before we get to settings: You have to make this thicker. Something one layer thick probably won't survive coming off the print bed. You don't need to change the model, just select your model, open the scale tool in Cura, turn off Uniform Scaling and increase the Z height to give it some thickness:
(Even 2mm is not really very thick, but I wouldn't even consider going below 1mm, pull out a ruler and you'll see).
Okay, on to settings (you might have to make all settings visible or search for some of these):
With all of those, you get this:
