On 2/29/2024 at 4:02 PM, Dustin said:that cross lines on the model is not correct..
it looks like you turned it into a support modifier object... check your modifier settings on the left side.
Yeah to fix the 2nd part of this issue i just need to right click the model and select the correct core
Dustin 130
