Posted · Some Cura Settings not Making it into the G Code File
Lines 35-36:
;LAYER:0
M107
The gcode output uses zero based counting for the layers, so 0 is the first one, and M107 is the command for "turn fans off". This is the fan being turned off for the first layer.
Lines 1892-1893:
;LAYER:1
M106 S255
M106 is the command for "change fan speed". This is your fan speed being set to 100% on the second layer.
