It's as designed. Some people run multiple versions of Cura side by side, for various reasons, some people run into bugs in certain versions, sometimes if they have more than one printer, one will only work in an older version of Cura, that sort of thing. Personally I have five versions of Cura installed side by side to help test problems are people are having so I can use the same version as them.
Slashee_the_Cow 277
XeroZar 0
Ok thank you.
