- Solution
GregValiant 1,260
Go to "Extensions / Post Processing / Modify Gcode" and then "Add a Script".
Ok, now I get it. Thanks!
would be nice if implemented in cura's settings having the possibility to choose heights and speed percentage change which would do it automatically and progressively.
Thank you very much
It is an easy thing to do in post-process so that's where it is. As you saw - there are many post processors capable of a variety of effects on the gcode. If they were all implemented directly in Cura then what is already a cluttered interface of over 600 settings would be completely unwieldly.
18 hours ago, Jerome85 said:Ok, now I get it. Thanks!
Thank you very much
https://marketplace.ultimaker.com/app/cura/plugins/5axes/CuraSlowZ
GregValiant 1,260
You can use the "Change at Z" post processor. The "Change Speed" option will insert M220 lines and all speeds will be affected (print, travel, retraction, prime). The setting is for a percentage so if you were to change the speed to 75% at say layer 700 and then use another "Change at Z" to make it 50% at layer 1200 you could progressively slow down.
A second option is to change just the "print" speed. If you use that then the travel speeds would be left alone, but you don't have any in vase mode.
Another post processor "Limit XY Accel and Jerk" will be available in Cura 5.7 but it's for bed slinger style printers.
Jerome85 0
Thanks for the replay.
Currently running the 5.5.0-beta.1 version, can't find this option.
I'll try downloading the latest version.
