Ive been working with cura to print very thin fibers. As I have progressed towards smaller and smaller fibers (now .09mm and .06mm diameter needle/fibers), Cura has given me trouble rendering the file to .gcode. My current solution is to increase the size of imported file by a certain percentage, generally around 300%. Obviously this is not ideal since I want to make the fibers as small as possible. I was just wondering if the fibers are too small to be printed by cura or if anyone has any suggestions. I also attached the .stl file I am currently working with.
kneuman 0
Thanks for your help in advance!
.09 diameter fibers v2.stl
