Bed leveling error after fan swap (losing my sanity)
As you mentioned you replaced the fan, its possible this itself is your issue.
The electronics in the print head are sensitive to electrical noise.
This can be expressed by smashed cables in the print head, faulty/damaged or otherwise out of spec fans, etc.
So you cant just replace the fan with a random fan from amazon for example.
A sensor value of 223 is basically.. "off the chart" as a bad value, as max accepted is 8.
Even your value of 10 points to considerable issues.
Anything higher than an 8 points to electrical interference/noise - this is what the article helps you troubleshoot and identify.
Dustin 129
UltiMaker does not offer direct support via the community.
I would recommend contacting UltiMaker support directly.
here: https://support.ultimaker.com/s/contactsupport
With that said the following article should help troubleshoot your issue.
here: https://support.ultimaker.com/s/article/1667410781005
